92 xp seadoo- engine runs fine but needs refired every 15 seconds. it does not matter at what rpm, you can instantly refire engine depending how fast you get to the starter switch. It seems like an electrical short, but always refires instantly. looking for any help in pointing me the right direction. thanks
92 sea doo-runs for 15 seconds then shuts off
Re: 92 sea doo-runs for 15 seconds then shuts off
Compression #s?Dan Solie -
I have not checked the compression. I can tell you ski runs normal, full power and does not slowly die just instantly shuts off like you hit the kill switch. it does not matter if your wide open or idling. when wide open if your fast enough you can refire before the engine even stops turning. I have seen some reference to the post/safety switch and i also suspect the kill switch circuit. but I suppose it could be anywhere in the electrical system(primary power) There are other threads in this forum for this exact problem on seadoo's but none of them addressed the problem. It is definitely electrical in nature.
seadoomanuals.netDan Solie -
