I recently read an article that said not to run tcw-3 oil in the Sea Doo Rotax engine. What oil should I run and where can I find it?
2 Cycle oils?
Re: 2 Cycle oils?
Try and run BRP oil available at seadoo dealers.Dan Solie -
Re: 2 Cycle oils?
XPS Seadoo 2 stroke oil is BRP`s own proprietary blend made by castrol. It is very good oil but costly... Even those of us that use good oil, cost is just one of those things that we deal with when running a 2 stroke... I won`t get into the great debate on oils as i have written/authored many threads on the subject on other forums...
Amsoil and Mystik are 2 other good choices and there are even more out there... I believe what the rotax needs is a JASO API TC oil...
here is a little bit of info about 2 stroke oil...
not a direct reply, but some good reading...
"Ashless" TCW3 vs. "Low Ash" JASO/ISO 2 stroke oil
There have been many posts lately about which type of oil to use. I stumbled on this quote in my collection today and thought it was interesting. Pay particular attention to the final paragraph...it reinforces what I've been saying here for years about which oil to use.
Quote from Spectro oils:
Most of the OEM manufacturers oils are produced by specialty lubricant manufacturers, not the OEM and these formulas are tested and approved by the manufacturer for use in their sleds. The oils are blended according to a formula that has been developed for two-stroke snowmobile engines and this oil is usually given a rating from the American Petroleum Institute (API) of "TC", the Boating Industry Association (BIA) rating of "TC-W", or the National Marine Manufacturers Association (NMMA) rating of "TC-W II." All of these formulas were originally developed for outboard engines and were modified to suit the needs of snowmobile engines; however, motorcyclists that used these oils found that their air cooled engines ran the best on the oldest API TC oils. These API TC formulas contained a higher level of bright stock 150, a high density petroleum base stock with a consistency similar to honey, that gave the best protection against piston seizure and bearing failure. To prevent carbon buildup in the piston ring grooves, these TC oils used metal based detergents that were very effective in motorcycle engines but caused some problems in outboard engines when operated at long periods of time at one throttle setting. A whisker-like bridge could form across the sparkplug gap to permanently foul a cylinder under these conditions while the motorcyclist operating his engine at a constantly changing throttle setting never encountered this problem. When the BIA developed the TC-W rating, they excluded the use of these metal-based detergents in favor of organic detergents to eliminate this problem in outboard engines. These TC-W oils (two-cycle, water cooled) also contained lighter base oils without the bright stock 150. For engines operating in the 4,000 rpm to 5,000 rpm range, the absence of the bright stock 150 had no affect on piston and bearing life. However, off-road motorcyclists testing these new TC-W oils were disappointed with the bearing life of their engines operating at 10,000 - 11,000 rpm and quickly returned to using the TC oils.
The need for a clean two-stroke outboard oil was recognized when piston ring groove carbonization was seen as a primary cause for engine failure and a new formula designated TC-W II was developed. While this oil was significantly better for outboard use and was phosphate free, it still was not the optimum two-stroke oil for engines operating above 8,000 rpm. The phosphate free mandate was from a concern raised by environmentalists that realized that outboard engine use could permanently pollute fresh waterways just as the soap industry was beginning to eliminate phosphates from their products for the same reasons. But, snowmobiles, motorcycles and quads do not emit their exhaust directly into the water, as outboards do. Recently, efforts to develop an even cleaner outboard oil have produced the latest NMMA TC-W3 and this oil, although containing no bright stock 150, has produced better levels of lubricity and cleanliness in piston ring groove areas, however, still not nearly as good as a purely 'snowmobile use' developed oil.
The BIA evolved into the National Marine Manufacturers Association (NMMA) which works closely with the outboard manufacturers. the NMMA mandated that all oils would contain non-metallic detergent additives, no phosphorus or phosphates, if they were to have the approval of the NMMA and the outboard engine manufacturers agreed to recommend only the NMMA approved oils.
Also, many marine dealers were concerned about the flammability and flash point of out board oils. Since larger engines were now consuming huge amounts of oil they had to stock several hundred cases of oil per season. This amount of oil stored in one location had alerted the fire marshals and insurance companies attention and a solution to this risk was addressed by the NMMA. Higher flash point oil with a flash point over 200 deg. F was what they needed to achieve a category 3B fluid rating, just enough to avoid the hazardous storage and shipping restrictions they were facing with all other two cycle oils. Oil manufacturers were forced to use TC-W3 additives or blends with high flash solvents if they were allowed to keep the NMMA license. The high flash solvents caused all sorts of unburned oil problems in engines, but the insurance carriers were happy.The combination of non-metallic detergents and high flash solvents in the new TC-W 3 oils later caused some severe ring sticking in many engines and Yamaha actually required owners to use a 'ring-free' fuel additive to maintain their warranty, a symptom of being forced by the NMMA to recommend the new oils!
This is almost exactly the same situation that developed with the American Petroleum Institute (API) and the Automobile Manufacturers. They were dealing with legislation that mandated exhaust emission systems to last a certain mileage under warranty and catalytic converter failure was known to be linked to the zinc-phosphorus content in motor oils. The API, in response to the auto makers, soon mandated restricted levels of these additives and is slowly lowering them. The problem was that motorcyclists depended on these zinc-phosphorus additives to protect their higher reving motors from damage and they were a victim of a legislation that did not even apply to them (very few motorcycles have a catalytic converter). Now snowmobilers are victims of this exact same legislative situation, the elimination of phosphorus from two-cycle oils. But they do not need to be! Why? Because motorcyclists and snowmobilers can buy motorcycle oils and snowmobile oils and bypass the restrictions placed on automobiles and outboard boats.
Sea-Doo and Ski-Doo didn't go with the NMMA, they refused to allow their engines to be destroyed and recommended to their owners NOT TO EVER USE TC-W3 oils! Polaris bought the TC-W3 sales pitch at first, recognizing an inventory advantage to having only one two cycle oil to be used in their watercraft, quads and snowmobiles. But they soon discovered the same problems many had already found with the TC-W3 oils when used in a sled. Ring sticking, exhaust port blocking and low temperature flow problems. Suddenly all those advantages of the TC-W3 oils they read about from the additive maker's brochures weren't working out when weighed against all the engine failures! Have you noticed they have gone back to purely snowmobile developed snowmobile oils? Currently there are not any snowmobile OEM's recommending the outboard NMMA TC-W3 oil, and there is a reason for this. They are not acceptable in today's powervalve equipped snowmobiles! Only oil companies with little actual knowledge of snowmobiles and their specific needs continue to try to sell snowmobilers an outboard oil for their snowmobile...and this is because they have a vested interest in doing so...economy of scale by combining several markets into one and selling just one oil. Do not fall for their sales pitch!
In Japan, engine manufacturers have developed a series of strenuous engine tests that can identify poor quality oils if they don’t measure up in performance. They tested over 250 samples of two-stroke oils worldwide and used the survey results to establish these engine tests. This became the JASO classification system. (Japanese automobile standards organization).
The tests include a detergency test, lubricity test, initial torque test, exhaust smoke test and exhaust blocking test. These tests have a much closer connection to actual snowmobile engine applications compared to TC-W3 tests which are all conducted on raw-water cooled outboard engines. And for the first time ever, an oil can fail the test if it smokes too much!
The detergency test evaluates the oil’s ability to maintain the cleanliness of critical engine parts, including exhaust power valves. This is very important on power valve equipped Rotax, Yamaha and Polaris engines. The lubricity test measures two things. First, the engine is run with a load for 50 minutes then the cooling system is disconnected for ten minutes and the resulting drop in horsepower is recorded. This cycle is repeated several times and each drop in power is compared and it must not vary more than a specified amount or be more than a specified amount. Then the engine is run with increasingly leaner oil ratios: 60:1, 100:1 then 150:1. If no seizure occurs and power is maintained within a specified percentage, the oil passes. The initial torque test measures the engine’s startability when cold, an important consideration for 3-cylinder sleds.
1998 SeaDoo Challenger 1800
sigpic
Re: 2 Cycle oils?
cont.
The exhaust blocking and smoking tests are run by mixing the test oil at an over-rich 10:1 ratio and running it in a two-stroke portable generator. The exhaust is channeled into a chamber where a photo cell measures the light that can pass through the smoke. It sounds crude but it works! Finally, a real world test to measure exhaust smoke from two-stroke engines! The exhaust blocking test simply examines the pencil sized exhaust outlet for carbon blocking. At a 10:1 ratio, these tests are very hard to pass. The highest JASO rating is FC. Lower ratings are "FB" and "FA." An even higher "FD" rating could be seen in the future. Most TC-W3 oils will not pass any of these tests!
In Europe, European two-cycle engine manufacturers were simultaneously working on two-cycle oil tests to separate the cheap, poor quality oils from the top quality oils. They tested the JASO reference oils in European engines and their top reference oils in Japanese engines. They found that European two-stroke high performance engines needed an oil with a better detergency and higher temperature performance than the best JASO "FC" oils. In April, 1997, they published their ISO global standards for two-stroke oils with two quality level categories: ISO-L-EGB and ISO-L-EGC. The ISO-L-EGB aligns closely with JASO "FB" and the ISO-L-EGC aligns closely with JASO "FC" for minimum test standards. Then, they developed the "GD" detergency test to run hotter and longer (3 hours vs. 1 hour) than the JASO detergency test. Oils passing the new ISO quality level, ISO-L-EGD would be superior to any previous two-stroke oils available! Of course, it didn’t take long for oil manufacturers to develop and test oil formulations that pass this new quality test, and most of them involve using synthetic base oils. Running these tests is a very expensive and time consuming effort but in the end, a bottle of oil with one of these JASO FC/ISO- L-EGD certified ratings means that the oil meets the highest quality tests set by the engine manufacturer in Japan and Europe.
Polaris, had recognized the "all-in-one" advantages of TC-W3 two-stroke oil, and recommended the use of TC-W3 oils in their watercraft, quads and snowmobiles for several years, have recently taken Ski-Doo's position....don't use it! Basically, specially formulated snowmobile oils that pass JASO FC/ISO-L-EGD and do not follow NMMA outboard engine additive restrictions will provide much better protection for higher rpm applications (snowmobiles generally rev higher than 6,000 rpm) and still provide a superior lubricity and detergency than TC-W3 oils at the same cost with less smoke. So, use snowmobile oil in your snowmobile and outboard oil in your outboard engine.1998 SeaDoo Challenger 1800
sigpic
Re: 2 Cycle oils?
and>
The Late Great Oil Debate
By Robert Verret
There are very few subjects that stir the emotions of PWC performance enthusiasts more than to ask, what 2 stroke oil do you use and why? This site has dedicated more ‘bandwidth’ to this subject than just about any other topic. Most of the discussions end up in heated debate with no one really changing anyone else’s mind on what oil is the best anyway. We tend to vehemently defend our choice as if our very reputation depended on it. I sometimes think we are more loyal to our favorite brands of oil than to our favorite brand of ski (hopefully Sea-Doo). Well, maybe we’re not quite that loyal to our oils, but close to it. If it’s any consolation, PWC performance enthusiasts are not the only group of “motorheads” that staunchly defends their choice of oil. I belong to several other performance oriented motorsport discussion groups (Ford-Diesel and Racetech-KTM) and they do it also. With all this said, let’s all take a deep breath and put our emotions and biases in a closet somewhere and try to look at this magic miracle ‘brew’ we call 2-stroke engine oil.
What’s in the stuff anyway?
2-stroke engine oils, like most other engine and gear lubricants, are composed of base oil plus an additive package. The additive package can be as simple (only one or two components) or as complex (multiple components), depending on the requirements of the oil.
Base Oil Types
Base oils compose from 50% to 95% of the total weight of the 2-stroke engine oil. They fall into 2 general categories: synthetic and petroleum based. There is a third category, vegetable, I will discuss later. Since synthetic oils are manufactured from petroleum, there has been a lot of litigation flying around about what really constitutes a ‘true synthetic’ oil in the last several years. There is no universally accepted definition for synthetic oil. Each manufacturer is free to label their product ‘synthetic’ by whatever rules the manufacturer chooses. The API (American Petroleum Institute) has defined base oils into 5 different grades or groups rather than use the terms synthetic and conventional (petroleum). The groups are classified by quality of their VI (viscosity index). The VI is a relative measure of the base oil’s ability to not thicken at low temperatures and not thin out at high temperatures. The higher the VI number, the more resistant the oil to changes in viscosity as its temperature changes. Perfect base oil would have no viscosity change at all with temperature change. Some silicone-based oils have extremely high VI, but, unfortunately, they are terrible metal lubricants, so they can’t be considered for engine lubrication. The higher the API group number, the higher the VI number. Most, if not all, high performance 2-stroke oils are manufactured using API group III and IV and occasionally group V base oils. GroupIII (hydrocracked/hydro-treated petroleum oils) are used in non-synthetic and synthetic blends and Group IV (VHVI and PAO synthetic oils) are used in full synthetic and synthetic blends. Group V (Ester synthetic base oils) is rarely used because of their expense and they do not mix easily with gasoline and they are not compatible with some other oils. There are a number of advantages to using synthetic base oil in addition to the better VI. Synthetics have a much higher flash point than petroleum base oils.
Synthetics will not decompose as easily at high engine temperatures as petroleum. The engine stays cleaner because less varnish deposits on the power valves, ring lands and piston crown. They also transfer heat better than petroleum-based oils. In summary, it’s fair to say synthetic based oils (with the correct additive package) will out perform their petroleum-based cousins at extreme loads/temperatures. I mentioned a third category of base oils earlier, vegetable or Castor (not Castrol, that’s a manufacturer) bean oil. This oil is derived from pressing oil out of castor beans and distilling it. ‘Bean Oil’ as it is often referred to, has some very unique characteristics; some very good, others not so good. The good is that it is an excellent lubricant. It seeks out hot spots in the engine and clings to those hot surfaces much better than petroleum type oils. The bad is that it does not mix with gasoline easily and it burns ‘dirty’ (excessive carbon/varnish deposits). In the early 70s, before power valves were used, castor bean oil was very popular in racing 2-strokes. Now that power valves are common and we have improved petroleum and synthetic oils, castor bean oil is seldom used anymore. Several companies still market it in the form of a degummed castor oil for racing applications only. It should be avoided for recreational use unless you enjoy tearing your engine down for a top end cleanup fairly often. Several manufacturers formulate their oil with castor bean oil as an additive (antiwear agent) rather than base oil. They blend it with their petroleum and synthetic base oils. When castor bean oil burns, it has an unmistakable ‘sweet’ smell.
Additives
If science could develop a base oil that would not thermally decompose (burn) until 1600 deg/f and not change in viscosity for –40 to 600 deg/f and not pollute the water or air, we would not need any additives in the base oil. Wouldn’t it be nice if all the oil collected in the expansion chamber body stayed in the same pristine state it went into the engine? We could simply recycle it. Well this isn’t going to happen in our lifetime (sorry, not even you younger guys will ever see this). Lubrication science is just not there yet. Additives are combined with the base oil to fix certain faults with the base oil or stretch the limits of the base oil in some cases. Additives are complex chemicals that account for most of the cost of a bottle of 2-stroke oil. Additives for 2-stroke oils fall into several general categories: Detergent/Dispersants, Antiwear agents, Biodegradability components, and antioxidants. Since the lubricating oil must burn as part of the combustion process in a 2-stroke engine, the residue resulting from this combustion process must be swept away after each firing stroke. If not, the residue (varnish, lacquer and other heavy hydrocarbon compounds) would build up and plug the exhaust port and stick the rings and power valve(s). Detergents/dispersants must be added to the oil to prevent this problem. The two types of detergents/dispersants most commonly used in 2-stoke oil formations are Ashless and Low Ash. Medium Ash and High Ash detergents are not used in 2-stoke oils. Ashless detergents are used in low temperature applications such as TCW3 oils where the ring land temperature is held below 300 deg/f. These detergents work well in engines where an excess of cooling capacity is available and power valves are not used. Ashless detergents are manufactured form organic nitrogen compounds (Hydrazine) instead of heavy metal compounds; therefore, they produce no ash as they are burned away. This is where the name “Ashless” comes from. Oils containing this type detergent have a characteristic Ammonia odor. Ashless detergents were used in the first generation of Bombardier XPS engine oil. The formulation was later changed to a low ash type detergent because of the higher temperatures generated by the 787 engines. Low Ash type detergent/dispersants are used in most API-TC, Jasco FC and ISO GC certified 2-stroke oils. These oils are designed for air-cooled high performance engines that operate under severe load/temperature conditions. Low Ash detergents can keep the deposits to a minimum at ring land temperatures as high as 400 deg/f. These detergents are manufactured from compounds of Calcium and Magnesium (heavy metals). After these compounds (Calcium Phenate or Magnesium Phenate) do their job, they burn away, forming a heavy metal salt (ash) that is swept away during the normal combustion process. Hence, this is where the name Ash-type detergent comes from. Ash type detergents depend on the higher combustion temperatures (787 and 951 engines) to keep the resulting ash swept out. Therefore, the use of these high performance oils in outboard or other mildly tuned 2-stroke engines is not recommended. Some manufacturers are using a combination of detergent types (Ashless and Low Ash) to provide a broader range of uses for their oil. It is important to note that oil designed to meet TCW3 specs. only (Ashless) will not protect an engine requiring API-TC (Low Ash) type oil. The converse is also true. Using a Low Ash oil in an engine designed for an Ashless type oil only could result in fouled plugs and gummy combustion chambers. When 2-stroke oil is kept in its temperature limits, it provides an adequate protective film between all moving parts. When that maximum temperature is exceeded, the oil film breaks down and usually seizure occurs unless another line of defense is added to the oil mixture. These are the Antiwear agents. These Zinc compounds (Zinc Dithiophoshate) flow in with the oil and are never used unless the base oil breaks down. If the base oil breaks down, they form a protective barrier between the moving parts (usually piston skirts and cylinder walls).
__________________1998 SeaDoo Challenger 1800
sigpic
Re: 2 Cycle oils?
cont.>
Since all 2-stroke engines partially burn and expel their lubricant in the exhaust, the resulting exhaust residue must be rendered harmless to the environment (air, water and land). All 2-stroke oil intended for marine use and many intended for land recreational use contain Biodegrading agents. These complex chemical compounds allow the microbes found in water and in the soil to consume the hazardous chemicals and oil from the exhaust as they fall in the water or on the ground. These Biodegrading agents do nothing for the performance of the oil (sometimes they even hinder it), but they help assure us that 2-stroke engines will be around for a while. As you can see, 2-stroke oils are a mixture of many different complex chemicals with base oil. Each specialty chemical has a job to do. Care must be taken to assure that these different chemicals detergents/dispersants, Antiwear agents, and Biodegrade agents) do not react or interfere with each other or otherwise impair the function of any other additive. Antioxidants are chemicals that reduce the chance of reaction between the various additives in the oil mixture. They effectively extend the ‘shelf life’ of 2-stroke oils.
What does ATP-TC and TCW3 mean?
Specifications for 2-stroke oils are developed from the design of the engine and its intended use (no surprise). Since this type engine has a wide variety of applications its no surprise that the specifications for the oils might vary also. For marine and PWC application there are 2 widely accepted standards for certifying 2-stroke engine oils. These are, by no means, not the only standards for 2-stroke engine oils. The European (ISO) and the Japanese (JASCO) standards have been developed, but these standards are not widely accepted in the country (yet). The standards most used in this country are the National Marine Manufacturers Association (NMMATCW3) standard and the American Petroleum Institute (API API-TC) standard. Both of these standards address the oil ability to prevent wear, keep the engine clean and biodegradability. Since these standards were written for different types of 2-stroke engines it stands to reason these standards would be different. Hence, the oils developed from these standards would also be different. The NMMA TCW3 standard was designed by the various manufacturers of outboard motors (Mercury, OMC, Yamaha etc.). These manufacturers so not utilize power valves, limit their max rpms to about 6800 and have excessive cooking capacity. They also must be able to operate at lower rpms for long periods of time without oil fouling the spark plugs. Although it’s true the performance of this type engine has increased in the last several years, the peak engine temperatures are still relatively low. The use of synthetic base oil in TCW# formulations has extended the useful range of these oils; their detergent system (Ashless) is designed for lower operating conditions. This is one of the reasons Bombardier specifically prohibits the use of these oils in their Rotax engines. The API API-TC standard was developed for Air-cooled, high rpm, high output 2-stroke engines operating under severe load conditions. Although this standard is no longer reviewed and updated since 1993 b the API, it still is in effect today. This standard most accurately addresses the condition Rotax and 2-stroke racing motorcycles and snowmobiles operate under. Almost all these oils are formulated with synthetic or synthetic blend base oils and all use a low ash type detergent. If you walk into a store that handles a variety of 2-stroke oils, it is relatively easy to find TCW3 certified oil. The manufacturer proudly displays that certification on each container. API-TC certified oils, on the other hand, are very difficult to find. There are two main reasons for this. First, many small API-TC oil manufacturers can’t or won’t spend the money (about $75,000) for the testing and certification process. Second, most engines requiring API-TC oils are for racing applications (Motocrossers and Crosscountry motorcycles) and don’t offer warranties with their engines anyway. The owner/operators of these machines know what oils work and don’t work. They do not need the API-TC certification on the bottle to help them decide what oil to use. There are many really good API-TC type oils on the market that have never been certified as such. Bombardier/Rotax is the only manufacturer that API-TC certified oils. The TCW3 market is about 10 times the size of the API-TC market. Outboard motor manufacturers require the use of TCW3 certified oils to maintain their warranty. With this great volume in oil sales at stake, it’s easy to see why TCW3 manufacturers can afford to certify their oils.
Rotax’s Position on What Oil to use
As we all know, Bombardier requires that an API-TC oil be used in their engines. Most other PWC manufacturers allow the use of TCW3 in their engines. So, what’s the difference? A PWC is a PWC, right? No, it’s not! Rotax marine engines evolved from their very successful snowmobile and motorcycle racing designs. These engines produce more power/cc than any other PWC manufacturer’s engine. Rotax designs these engines to work harder and run hotter than other brands. They simply need more protection than TCW3 oils can give. Those that use TCW3 oils are risking high temp. Seizure if the engine cooling system plugs or and internal fuel filter plugs (lean condition). These things may not happen very often, but when they do, it’s better to have a little extra protection that only a TI-TC oil can give.
So, what’s the best oil to use?
I truly believe there are no bad oils anymore (well, maybe a few really cheap ones are not so good). Most problems with oils are the result of misuse. I had a friend once that insisted on mixing STP with his premix. He swore his motor made more bottom end with STP in the fuel. Well, it may have, but he invested considerably more $$ in spark plugs than just about anyone else on the planet. He was also responsible for single handedly stunting the growth of the entire mosquito population in southeast Texas (thank God he quit riding). I hear a lot of complaints about the high cost of some 2-stroke engine oils, mostly Bombardier XPS. Well, I have to agree, it isn’t cheap, but neither are any of the other API-TC oils compared to the TCW3 type oils. Unfortunately it just costs more to manufacture API-TC oils than TCW3 oils. Despite its relatively high cost, I cannot recall any Rotax engine failing because of XPS oil. XPS oil was a joint development of Castrol and Bombardier. Bombardier wanted a ‘universal’ high performance engine oil that they could use in all their recreational products. That meant oil would flow freely at –40 deg/f and still maintain sufficient film strength at 350 deg/f. The first generation of XPS (1995) was formulated using Ashless detergents; this allowed the Rave valves in the then new 787 motor to stick. The formula was later changed (1996) to a low ash detergent that eliminated the rave valve sticking problems. There have been several minor improvements in XPS since 1996. Castrol remains the only manufacturer of XPS. This is a proprietary blend sold only by Bombardier.
There are a number of good API-TC type oils out there if you chose not to use XPS. If the oil you want to use does not have the ATP-TC certification on the container, contact the manufacturer. Most of them will be more than glad to provide you with information on their products.
sigpic
Re: 2 Cycle oils?
cont.>
Decisions, Decisions!
Well, I hope I answered most of your questions concerning 2-stroke engine oils. I’ve tried to keep brand names and my personal biases out of it so far. However, I, like you, have an opinion. My opinion is based on my 30 years experience working with 2-stroke motors and my relationship with some very knowledgeable people involved in lubrication research. I work for the world’s largest manufacturer of oil additives. We make the additives for virtually all the oil retailers.
Now having said that, here are my recommendations. If you have a Sea-Doo PWC that is still in warranty: Stay with XPS or XPS-DI. Sure there are API-TC certified oils that should preserve your warranty, but in an engine failure the dealer could cause you grief getting your PWC warranted. In my opinion, it’s just not worth the hassle to do battle with them. Stay with the XPS at least until the warranty expires. After the warranty expires, select API-TC oil that carries the certification or confirm in writing the oil you want to use is designed for your PWC. Then find someone else that uses the oil you are considering and get his or her opinion. Do not use TCW3 in your SeaDoo PWC. I don’t care if it’s a full synthetic or your brother-in-law uses it; for the reasons stated above, it will not protect your motor when conditions get tough in your motor.
Choose well, the life of your motor depends on it!1998 SeaDoo Challenger 1800
sigpic
Re: 2 Cycle oils?
Your welcome. This was just shared info that`s around on the jetski forums as well as the sled forums. When I had Doo`s I used the XPS and just knowing it was a proprietary blend made by7 castrol was enough to keep me buying it regardless of cost.Originally posted by Grimmy View PostThanks for the reply. The late great oil debate is the article I had read. Thanks for shedding some light on the this for me. I am now runnig the xps oil. Great info!
Citgo makes many 2 stroke oils for Yamaha including 2W and 2S and also Citgo makes Mystik lubricants as well. Citgo sea and snow goes by several labels and you can read the MSDS reports to see which are the same oils or equivalent under brand names...
Personally I have used XPS in the doo, and Yamalube 2W, Mystik synthetic and Amsoil Interceptor in the GPR...
without causing a debate, people who purchase off the shelf oils really should pay attention to the specs. Simply put the outboard type oils are for low revving outboards and not really meant for the high performance high revving, high load 2 strokes... many get away with it until blank blank blank...
I do understand where your coming from, even ordering a case of 4 gallons online to save a few bucks, the shipping always kills ya... it`s wether or not the dealer has the oil in stock, how much oil you burn in a season, and if the total cost justifies your needs... good luck!!
sigpic
Re: 2 Cycle oils?
I have been running Quicksilver PWC synthetic blend in my 787 Seadoo. It says on the gallon jug not to use it where a TCW3 oil is called for. I ride very aggressive and have never had an oil problem using this oil. $27.00 a gallon verses $37.00 a gallon for the Quicksilver full synthetic at Wal-Mart. I have been told on this forum that the oil I am running is just fine.
