So you got a Speedster...pretty cool little boat. Your getting ready to launch with the family and only 1 engine will start. Soooo can you run the weekend on 1 engine or is this just a setup to fill the other engine up with massive amounts of water without a hose pincher?? Or another example your in a no wake zone and wanna slow down a bit so you idle in on 1 engine...OK? or no bueno?
96' Speedster...Run 1 engine at a time IN the water?
Re: 96' Speedster...Run 1 engine at a time IN the water?
The boat should be used with both engines running, if one is broken dont run the boat.SBT Tech Support is here to help with your problems.
