My xp seems to run on trailer. Spark at both cylinders seems good. Has new computer ,coil ,wires plugs. Runs in water about 5 to 10 mph, won't plane out. Seems to smoke more on trailer than my GTX. Any help would appreciated.
96 xp runs bad
What RPMs are you getting? Is the oil pump correctly adjusted? Where are the carb needles set? Any mods? Have you ever seen it run correctly?SBT Tech Support is here to help with your problems.
Seems to rev up okay. Never adjusted oil pump never had reason to. How can I check carb needles? Last season it would act like this seemed if you would work throttle it be okay for rest of time. And yes it had run fine before. With any reason this started. Thanks for your help.
