Does anyone know if I can fix the black plastic hose connector that the cooling hose connects to on the jet pump. The piece broke off and I don't know if I can fix it, glue, etc or do I need to get a whole new jet pump housing unit? Thanks.
94 xp cooling hose connector broke on jet pump housing?
Re: 94 xp cooling hose connector broke on jet pump housing?
Glue will not hold, if you can thread a tube into the housing you might be ok otherwise replace the pump.SBT Tech Support is here to help with your problems.
