I am working on a freinds ski and rebuilt the pump with a SBT pump rebuild kit with a wear ring and also put in the carbon ring and floating washer. Put the ski in the water and at idle you can feel thrust coming out of the pump but when you give it throttle the ski starts to vibrate and doesn't have any power to even try to get up on plan.
It was doing the same before the pump rebuild (I thought it might be because of the grooves in the wear ring) at least the carbon ring is keeping the water out. It is an 04 RXP, any help would be appreciated.
Thank you.
Thank you.
