Here is what we have. Had a problem originally with my Magnito, it broke a bolt head off the flywheel and tore up the magnito (shorted out). I fixed that problem with another magnito, sensor coil and new plug that goes through the case. All wiring is good in the magnito. I noticed a small short nothing enought to blow a fuse. It will discharge the batt over night. If I unplug fuses one at a time, with an ohm meter on the battery terminals, here are the results. 15 amp fuse with the 2 spark coils is good. The fuses in the Memp starting at the top one and going down are No change, No change, and the 7.5 seems to change the short to not there. This fuse is acording to the book Memp fuse. Can this be a soder problem or what. The thing I believe will still start it just frys the batt over time. The book also says to look at the regulator (not sure where this is other than the Memp itself. I am still trying to get this going by next week end. I have also noticed the gas gage and the speedometer do not work. If I unplug the gas gage and the speedometer there is no change to the short. Thank you for any help in advance.
Toolmaker
Toolmaker
