ok, so the ski will run great- but my kid has had this occur 3 times, and the last one we couldn't get refired on the water.....it stalls out...dies...like the lanyard was pulled out. I have noticed one consistent thing..its at higher speeds and throttle almost mashed..I suspect a fuel pump issue...now the fuel gauge does not work on this thing either...so could the sending unit be causing an issue??? I am going to see if the diaphram is sticking...regqardless..Im gonna rebuild the pump I suspect....anyone else got any ideas?
The plugs were dry after this happened...btw....
