I have been trouble shooting a "hard starting in the water" problem and after a compression test (150, 155) and resistance testing all sensors (TPS, CPS, ATS, WTS, APS) I hook everything back up to find NO SPARK. 5 Vdc at ignition coil when I depress start button with no lanyard attached. Primary resistance check of coil shows resistance readings within specifications. I double checked MPEM connections, I get 2 beeps on lanyard install, engine cranks fine, battery is at about 12.5 Vdc, I have plenty of fuel going into cylinders and have verified no spark at plugs oh and I tried new plugs since I had a set.
5A fuse in MPEM is good, all fuses in in battery box are good
Also checked battery ground, coil ground and mpem ground...all good
It was starting just fine on the trailer...now no spark. Is there a way to test if the coil is receiving signal from stator/mpem to spark the plugs? Or any other tests that anyone recommends?
