2001 GTX Di
  • 2001 GTX Di
    Hi there,
    I just boght the new engine 951 from SBT to replace the damage one after installed the engine
    I was facing with a minor problem
    1. If i put fuel in the spark plug then the engine was run fine
    2. But it won't start after i stop it
    3. the fuel pump running and pump out fuel when i plug the key in
    4. when I took to dealer they told me the fuel pump not enought psi need a new pump
    what can i do now or anyone have the same isue? or that tru i need a new fuel pump? that pricy cost like $799.
    Re: 2001 GTX Di
    If the fuel pump is bad then it has to be replaced.
