Was rebuild jet pump and reinstalled the pump, taking it to the water and runned good until the c-clip on drive shaft felt off and carbon seal started to leak alot.
Filling the hull maybe to drive shaft..
Was just going to fix c-clip and carbon seal then I noticed it was water inside engine?
Why? Could it be just because I filled hull with some water or something wrong when I installed pump?
Thanks for any answer!
BTW It's a ski-doo xp 1997
