Fuel problems 99 seadoo gtx rfi
  • Fuel problems 99 seadoo gtx rfi
    Checked fuel pressure on this boat it is right at the minimum
    Pressure but when I pull the fuel rail out it will squirt fuel good and then it goes to a
    Fine mist could the fuel pressure regulator be bad ? Or could it be the fuel pump ?
    It will run on hose fine but when it is in the water it bogs And want reach max rpm's. Every thing checks out good like the rave valves,air pressure sensor ,temp sensor .The injectors are fine also . I just need some ideas on this boat any help would be nice
    Re: Fuel problems 99 seadoo gtx rfi
    Yes it could be a fuel problem, but also could be a clearance issue between the rotary cover and the rotary face, too much clearance and the ski will not run under load (in the water). Check clearance
      Thanks I will check that what should the clearance be and i will let you know
        With the valve installed no more than 14 thou
          Thanks will check it
            sounds good
              Check the clearance it is good checked timing it is good
              The only thing left is the fuel pump now I guess
              I was thinking about a used one or do think I need to put
              a new one in there.
