Checked fuel pressure on this boat it is right at the minimum
Pressure but when I pull the fuel rail out it will squirt fuel good and then it goes to a
Fine mist could the fuel pressure regulator be bad ? Or could it be the fuel pump ?
It will run on hose fine but when it is in the water it bogs And want reach max rpm's. Every thing checks out good like the rave valves,air pressure sensor ,temp sensor .The injectors are fine also . I just need some ideas on this boat any help would be nice
