I Just finished putting in a rebuilt sbt 587 in my 1993 gtx. Rebuilt both carbs, pump. It will not start. Back fires but wont run. getting fuel, and spark. set timing as per sbt instructions. where do I go from here? If I set timimg at 130% as stated in instructions. Do I change this to Plus 130 or minus 130 and how much? If this is the problem !
Doug
Re: Doug
I replaced the flywheel that was on my engine. I ordered from you a 587 1993gtx engine which is the flywheel that came from my engine (same Model). The engine I replaced was running when I took it out (Had bad compression But running). Using the degree wheel I set the rotery timing (as per your installation directions.) at
130 %. I had to turn the r/v over to hit 130 exact on this new engine. On my old engine it was set at 130 also. ( I marked the side from my old engine prior to removing for referance) All I get is pop-pop backfires out of exhaust and back through carb, but won't run. Should I go - or + if i reset the rot/valve? Also stator was aligned to your instructions. I have rechecked all ??
