Is there a source you can point me to for a Center gear for a
Seadoo 947/950 DI crank shaft. When I look at Seadoo parts manual
the crank shaft is not broken down into the individual parts. So I can't
simply order the gear from them. This is not unusual as Seadoo parts
lists normally show the crankhaft as one part. Even though it can be
broken down into rods, bearings, etc, from various second sources......
So I've had no problem getting parts for other Seadoo crank shafts, but
I'm having real difficulty finding a source for the Center gear for a Seadoo
947/950 DI crank shaft. I'm hoping the forum can help me source those
parts.
thanks
Frank
parts.
thanks
Frank
