Flywheel puller Is this all I need? Crank quesitons
  • Flywheel puller Is this all I need? Crank quesitons
    I need to replace the starter bendix on a carb 951. I've never pulled a flywheel before. Is this http://www.shopsbt.com/mm5/merchant....ct_Code=80-107 all I need, nothing else for the Mag side?
    What do I need for the PTO, the chain wrench?
    And one more question...for the 951 crankshaft from SBT, can I pay you to pull these things for me and install on the new SBT crank if I go that route?
    Thank you
    Re: Flywheel puller Is this all I need? Crank quesitons
    Yes that is the correct flywheel puller, We would not be able to help you with the installation, we only sell parts or assembled short blocks as for the pto coupler on the 951 you un bolt the rear coupler section then another bolt is behind that, you will need a gear puller to remove the rest. Go to seadoomanuals.net and down load a free manual, this is the best tool for working on your own engine.
      Is there a universal puller that does both?
        No, use the http://www.shopsbt.com/mm5/merchant....ct_Code=80-107 for the flywheel and use a 3 jaw type on the pto after the center hub is removed and the center bolt is removed. Follow the service manual.
          Thank you for the information, I see the differences now.
            Glad we could help.
