Does anyone know where the fresh water flushing port is on a 2001 seadoo gtx or do you have to buy a flush kit for it? I cant find it.thanks gary
Flushing
Re: Flushing
Its on the side of the jet pump, a garden hose screws into it, make sure the engine is running before you turn the water on and turn the hose off before you shut the engine off other wise you will flood the engine with water.SBT Tech Support is here to help with your problems.
