1992 sp wont start removed kill wire from coil . original problem was in the stator it had no spark at all . replaced it and the coil but now only firing on #1 cylinder. re installed old coil it sparks on both cylinders . the motor acts now like a fuel problem . it was running fine last year. cleaned carb but may be pluged again .so do you think the new coil is bad or another problem?
1992 sp coil only firing on one side
