installed new 717 from sbt and it ran when i cranked it at first (after i cleaned plug connector at mag and had spark). It seems to have both fuel and spark but will not fire up.Does anyone have an idea what might have gone wrong? I replaced plugs and the fuel is new 32:1 mix no oil pump.
new motor no start
About the only thing fairly common is to have the brass gear strip, if your valve or cover is at all damaged. Very that it is still in time. Does it start at all if you put fuel right down the spark plug holes?SBT Tech Support is here to help with your problems.
It will do that if your needles & seats are leaking & flooding the engine with gas.
when you added fuel in the cylinders & carb...it just made it worse.
Turn off the gas, remove fuel line & try to start with the throttle held wide open.
If it starts & smokes like hell...you found your problem.
I only know this by experience! went thru the same thing....
motor ok checked timing and all works well there. found weak spark and cleaned fuse ends of corrosion in controll box. this fixed starting problem but motor quits for lack of fuel and will not hold fuel in line. suspect it may be air leak or the spring i used in rebuild of carbs may be to strong. Any ideas will be much appreciated.
So in your first post when you said it had spark - it didn't?
Make sure you don't have the fuel lines switched at the carbs.SBT Tech Support is here to help with your problems.
