I pulled the pump to inspect. Everything looked really good. The question i had is, should the driveshaft be secure in the impeller or should it be able so slide out of the pump very easy? When I put things back together I had a lot of play in the driveshaft as far as being able to move the driveshaft back and forth. (front to back) Also looked like water would be able to enter the hull in between the rubber boot around the driveshaft and the Spacer thing (the piece that butts up to the boot), I do have the clip on the driveshaft. Did i do something wrong?
'96 gtx pump
Yea...there's a good 1/8" of clearance all around the shaft and the "spacer thing". (ring carbone)
It seals on the front flat surface against the metal flange on the shaft.
I never thought it would seal out water either, but it does! ....as long as there are no grooves or gouges in either surface.
Check both ends for those rubber pads, and grease it up good at the splines.
Yup, just buy a spacer or two from your dealer, pull the pump and shaft back and pop it in.
[ September 09, 2003, 09:23 PM: Message edited by: Technical Support ]SBT Tech Support is here to help with your problems.
