4 tec problems
  • 4 tec problems
    2- 4 tecs came in and I am not familiar with them. the first one will run rough and has the rear spark plug smashed in. the second one started briefly , ran terribly and seized. it's front spark plug is smashed. same problem? terminal? common with these?
    Re: 4 tec problems
    Early 4 tecs had valve issues, rear cylinder was known for dropping valves. The rear cylinder runs the hottest so that's why it's typical for that 1 but the front cylinder to break a valve is rare.
      Re: 4 tec problems
      I have to do research to see if this motor was rebuilt by someone locally or a rebuilt motor was installed. I doubt that it is an SBT, I will look for a sticker. I have a feeling that this was a used motor and sold to this customer as a rebuilt. I am talking about the one with front plug smashed. That is my main concern as the installer had the wrong drive shaft and pieces put in and I bought the SBT kit with great success. I wind up with these problems after fly-by-nighters mess things up. I am obviously in deep now. The one with rear plug damaged is not even in the yard. It might have been the middle one, I did not take notes. I am in the middle of a ton of winterizing jobs.
        Re: 4 tec problems
        If we can help you out with any parts then let us know.
