I just bought a 06 rxp with a blown motor. I pulled the motor apart and noticed it had sbt bearings in it. Looks like the person rebuilt it. Anyways the main bearing has 23-112-40 on it and the rod bearing has 23-112-50Z on it. I was just wondering if the bearings are standard size or if they are over sized bearings. Thanks
4tec bearings question
Re: 4tec bearings question
They need to be measured to tell the size. SBT does not have 1 standard bearing that fits 1 standard rod, we sell bearings the same way the automotive industry does, everything MUST be measured to get correct combination.SBT Tech Support is here to help with your problems.
