I bought a 1995 SeaDoo Sportster with a locked up engine. I tore the engine down and found the crankcase was full of sludge and rust. The block is junk. Anyway, this boat only has 73 hours on it and is in perfect condition including the electrical.
I am looking for a donor jetski with a rebuildable engine and for other parts, but was wondering if maybe I couldnt go to a bigger engine.
From the schematic, The ignition module is external to the microcontroller. I dont see any real engine management except for safety kind of stuff (Revs, overheat, gauges). The microcontroller does take some critical inputs such as start/stop, ignition switch, safety switch, neutral switch. Etc. But I can work around that.
Anyone have a suggestion for an engine swap that would push up the horsepower and fit without engine mount or pump modifications? It would need to be an engine that does not require emissions control.
Randy
Randy
