Drive shaft bearing
Re: Drive shaft bearing
I removed the pump and the driveshaft bearing. It's the driveshaft seal that came out. There is zero Loctite and the hydraulic pressure from the grease alone was enough to push this seal out. I wonder if i can ever get it to seat again.
I bought this from SBT. This looks like a quality control problem.
Since sbt techs don't want to jump in. Ill leave this here:
I cleaned all bearing grease out of this brand new carrier, used alcohol to degrease the metal surfaces. I had some anaerobic sealer used for mating crankcases and coated the metal surfaces, and pressed the seal back into the carrier. I put it all back together knowing I'll have to watch it and there's a strong possibility I'll have to do it again sooner or later. Here it is fixed:
Please contact our warranty department.
If this is a recent purchase we can get a new one out to you.
Call 877-330-0231 ask for warranty department.SBT Tech Support is here to help with your problems.
The seal has stayed in so far, but haven't really run the boat but on the trailer (see my other thread about won't idle)
I used an anaerobic gasket maker and tapped the seal back in the housing with a block of wood and a ball peen hammer. Seems good now.
