I have a 1993 Seadoo SP (587 engine); after it sits for awhile oil will leak from somewhere underneath the engine (I think). Are there seals that can go bad on the bottom of the engine or is there something more that may be wrong here? Any help would be appreciated
Mystery oil leak
Re: Mystery oil leak
there could be a bad o-ring on the rotary valve cover, a cracked oil line or the plug on the rotary valve section could be corrodedSBT Tech Support is here to help with your problems.
