I just finished replacing the top end on a 1999 XP 947/951 and it would quit as soon as the starter button was released. I found some information that said if you disconnect the TPS and if the engine runs but won't rev to 3000 RPM, the problem could be the TPS. If I disconnect the TPS, the engine will run up to 3000-3500 RPM. I have looked at the Sea Doo repair manual for diagnosis of the TPS but could not find anything. The wiring diagram is not much help either. I would like to make sure that the TPS is the problem before I replace it. Does anyone know the voltage and resistance specs for the three terminals on the TPS?
Thank you, Gil
Thank you, Gil
