1996 Sea Doo Speedster Rev Issues
  • 1996 Sea Doo Speedster Rev Issues
    I recently purchased my first boat. A 1996 Sea Doo Speedster Bombadier with twin 787 rotax engines. I recently replaced the spark plugs in both engines. Runs pretty good however sometimes the right motor will act up. The problem I am having is that it will rev up to 7000 rpm and not go anywhere. As soon as I hear it start pinging, I release the throttle and pull back because I'm worried about overheating, etc. Any recommendations on what I should do next? New wires, clean carbs, and new filters?? Any advice will be appreciated. Thanks!
    Sent from my SM-G920V using Tapatalk
    Re: 1996 Sea Doo Speedster Rev Issues
    Sounds like cavitation. check your propulsion system. Impeller, wear ring, pump seals, and carbon ring on driveshaft.
