1050 Phase III, Buck 50's, coffman with 15/24 swirl on 85 exit nozzle at sea level. I was at 175 main and 130 pilot. I was close to fouling a plug. Could feel it. I found the Y line barb that came with vapor separtor had a 60 return jet so I feel was overpowering the carbs. I changed return jet to 110 and rejeted to 170 pto and 165 mag w/120 pilots. I was loading up pretty heavy. You can say all you want, but most plugs will read decent at 73-7500 unless you are way, way, off. Considering this, what in your opinion min and max main jetting my setup. I am thinking a max of 175 on mains and and minimum 160 min on same. So I should be somewhere in there.
The pilots I always set up so as to take off clean.
Yes. I would like an egt setup. .. How fast does a siezure happen. I was running around 7250-7300 with aforementioned jetting. I figure was way to rich.
