As soon as I let off the start button, the motor dies. Bill O'Neal just did a rebuild on this, but he has no idea what would cause this. Any help appreciated. 2 hrs on rebuilt motor. Battery is new. Compression is good.
99 XPL only runs with start button pressed
Replace the throttle cable.... There is a sensor in the middle of the cable for throttle position, for ignition timing and for RAVE opening and it is broke, or is worn, and will cause exactly this problem. Replace the cable, properly adjust the slack on all parts of the cable, and the problem is solvedJohn Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
John,
What is the correlation between the cable TPS and the stop button? I'm not doubting the cure, just curious as to the cause.
Ray, before you replace the cable, pull the front glove box out of the hood. Underneath it is a bunch of wires and the throttle cable. On the cable is a bullet shaped adjuster. Try adjusting it to another position, then test it again. Those cables aren't cheap. I'm not sure if that will help, but it is worth a try.Bill O'Neal WCM
Bill, I do beleive I was told that the switch fails and eliminates the less than 80% signal from the MPEM input, when this happens, the MPEM gets confused, and shuts off. During starting the MPEN sends a different, retarded ignition trigger to get engine to start easily. Once you let of the button, there is no trigger signal, so the engine shuts down, as if you pulled the lanyard.John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
Thanks John,
This is the first time I have had someone ask me this question, and I have never experenced this paticuliar problem.
There is a test to perform on the TPS. It must produce 5 volts at different settings, showing that it works. Using the adjuster on the cable, you can make it send the 5 volts at the correct time to the MPEM, which retards the motor.
As I had adjusted his cable when he had his boat in my shop, I suggested that he try re-adjusting it before he spent the money on a new cable.
Thanks for the imput John.Bill O'Neal WCM
Not going to believe this one guys. I triied for 4 days every trick Bill O'Neal and John Kubiak suggested, with no change...it still only ran with the start button depressed....died like I pulled the lanyard when I let go of the button. Just as I was getting ready to get online and order the $160 throttle cable (can you believe that!!), I decided to do the last thing I did before the ski stopped running...disconnect & reconnect the battery. The **** thing ran like one of Bill's rebuilds always does..purrs like a kitten WITH MY HAND OFF THE STARTER!!! Just thought I'd pass this back to Bill & John for a future Seadoo owner who has this problem. Now I can go TEAR UP San Diego Bay again!! Ray (SMILING again!) Hinton
[ August 29, 2002, 10:14 PM: Message edited by: Ray Hinton ]
Gee, I guess the last eight skis with the throttle cable causing the same problem that came through my shop when I was a service manager were just a figment of my imagination! Imagine that, and Sea-Doo paid for the repairs, especiailly since they directed them!John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
Hmmm, imagine that!!!! Thanks for posting about your resultsJohn Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
TPS failuire very common on 99 951s espically XPLs because the connection is not sealed and water gets into the circut board and shorts it out (located under oil tank).
This can be prevented by smearing the connection with grease.
2000 version TPS changed.
Just another example of Bombardier not testing their products before releasing to the customer and not standing behind their product after the one year warranty. That 99 TPS problem should be warrantied no matter how long because it was so obvious. As if 99 XPLs don't leak water through the front, har har97 GP1200/99 XPL<br />Head, intake and handling mods on both
