oil in cylinder on 96 Challenger engine
  • oil in cylinder on 96 Challenger engine
    Thought I had an electrical issue because I couldn't get the engine to turn over. Pulled plugs and am getting some oil out of one of the cylinders. Can it be cleared out so I can finish the season? Is it possible to winterize engine if I can't get it running? Also, what are all the possible causes of the oil in the cylinder? Thanks for your help
    You most likely have sho inner crank seals and need a new crank or engine. If you want to try pumping it out before you start it, it will run fine, but only get worse. No you cannot winterize if you cannot start it.
