HEre is a couple of good ones for you guys. Took the boat out this morning. Ran great for 1 hour or so. Parked it on the beach and let it sit for a while.
Got back on it and it developed a occasional "sneeze" or backfire through the carbs when accelerating or when running at close to wide open. Would do it once every 30-45 seconds or so. Did not do it at idle.
Next weirdness of the day. PArked it to think about it. Got back on it and found my kid had left the lanyard plugged in. Pulled it off and put it back on .Boat would not start until you let off the start button. It would crank but never catch until button was released. Then i [img]graemlins/cwm3.gif[/img] t would run for 5 seconds and die as if it was turned off.
Could this be something with the DESS system??
Got it home and started it up to flush it and it ran fine. no quitting.
suspect the front carb is a little rich. If this needle was leaking could it cause this "sneeze" problem??
Help !!
Thanks in advance
Smitty
Help !!
Thanks in advance
Smitty
