1500 rpm idle 2000 Gtx Rfi
  • 1500 rpm idle 2000 Gtx Rfi
    Can't quite get it to idle at 1500 rpm's. Either is above 1600 or below 1400 when using idle adjustment.
    Also how much does it throw of the alignment for the oil pump when adjusting the idle
    Any tips? Thanks
    davidj
    Idle adjustment needs to be set by a dealer's MPEM programmer, or their B.U.D.S. system. The RFI has a "mapped" fuel and ignition program based on the throttle's idle stop setting. when you adjust the idle without resetting the mappped progam, you can seriously degrade the overall performance of the PWC.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
      You now need to take it to the dealer for ajustment, if you messed with the screws yourself. There is nothing you can adjust on an injected motor at home.
        when I put the new sbt motor in and fired it up the rpms were below 1400, so that is why i messed with the screw.
        thanks for the help
