I recently bought a 96 XP. It is in very good condition but sometimes it starts bogging really bad. When it runs right it screams (54.3 on GPS) but when it is cold or letting off the throttle sometimes it runs really rough and won't plane out. After a minute (sometimes several minutes) it kicks backin and screams. It either runs really good or really bad. I am wondering if I might need a carb rebuild. It is acting like the float is sticking or something. any thoughts on what else it could be?
CARB PROBLEMS??
It is highly likely you need a carb rebuild. While you are rebuilding (whether you do it or have a shop do it) I would recommend purchasing aftermarket flame arrestors with a rejet kit. You will get a more responsive engine and also will have higher reliability due to the richer mix.
You might also want to check the compression on each cylinder. Is the boat stock? If so you should see around 145psi in each.
I checked the fuel filter this morning and it had a little bit of black crap in the bottom of it and the screen part looked like it had fallen off into the bowl. If this is the case I wonder if I have some crap that got into my carb. I took it out today and it is the same thing. i pulled the plugs and they look kinda foouled even though they don't have much time on them. I'll put in a new set and try again tomorrow.
