I was trying to get my gas tank out of my 96 GSX (at least tipped to get the tube out of it). I am now convinced it is impossible. This has the large 15 gallon tank. While putting the tank back I noticed the check valve nipple for the oil tank has no hose on it. Is this just for air and doesn't need a hose? I looked on my XP and it has a hose that is about 8 inches long but has nothing attached to the other end. I can see a hose clamp used to be on it. Is this just for venting and connects to nothing, or someplace safe to get air without sucking water? If so where does it connect?
oil tank check valve
