When held up to a bright light and looking thru the impeller housing assembly I can see on average a 1/32 inch gap around most of the 3 impeller blades and the wear ring.
Is this okay or is it a little to worn out and should be replaced (wear ring)?
Also if it does need replacing should I get OEM or I've seen one that is plastic but the inside is lined with stainless steel ?
It's sold thru Dennis Kirk and marketed for people that use their skis in salt water (which I do).
Thank You,
Joseph
[ September 24, 2003, 11:31 PM: Message edited by: cobrajoe ]
Thank You,
Joseph
