HX starts but can't get it to keep the gas going. When to give the gas it dies. The idle is set really low for racing purpose from what I was told from the seller. It also smoke like crazy while I'm trying to do it outside of water. I spary a little starting fluid just to get it to fire up. I'm new to all this stuff
Hx starting problem?
First make sure your compression is good, from there you need to look at the carbs and make sure the diaphrams are ok and the pop-off is set correctlySBT Tech Support is here to help with your problems.
check your fuel filter for and lines. there is a small filter in both carbs which get clogged up but if your just getting into these thing get a good mechanic to check that for you. do you have to premixyour gas? if you do thats probably why its smoking a lot. the idle can be reset real easy. there is a low and high speed screw on both carbs, dont mess with them. go to this link: http://216.37.204.203/Seadoo_OEM/Sea...pe=13&A=32&B=9
the idle adjusting screw is umber 33. turn it until it idles at 3000 rpm out of the water/1500 rpm in the water. hope this helps.
