Is there a way to check the needle and seat without taking the carbs off using a pressure gauge?
Checking needle and seat.
Thanks for the help. Another question, in my manual it says to check the fuel pump operation to hook a hose to the "in" and blow in and out to make sure the check is working properly. Does this only apply to the MAG side? This supplies the other carb also, correct?
Only a carb with a pump, yes - and be careful breathing in fuel vapors. No Factory manual states such a procedure that I'm aware of. I would use a vacuum gauge if you have one.SBT Tech Support is here to help with your problems.
