I am going to clean the internal filters on my carbs, while in there I will replace the needles and seats. 96 gtx, runs ok but wet/black plugs and tricky to start. My question is how much additional work is involved in rebuilding the carbs or should I just do as mentioned above if they run ok? Don't want to do unnecessay work if not needed. thx..
carb rebuild
Read the articles here, watch the vids, look through the rebuild guides - all here in the video and tech sections.SBT Tech Support is here to help with your problems.
I clean filters and replace needles and seats more often than not. I usually do not have to rebuild the whole carb, unless I see a reason to do it.
DO NOT DIP CARBS INTO CARB CLEANER if there is even one rubber or plastic part left on them. The carb cleaner will eat them.
I never dip my carbs. I use a spray cleaner.Bill O'Neal WCM
