hi all, got my ski back in the water after installing new sbt motor and rebuilding the carbs. with the ski on the trailer conected to the garden hose how much noise should be coming from the pump end of the ski. it sounds grindy and when you put your hand on the pump housing you can feel it coming from it.
will motor alignment do this ? i just put the motor back in the same spot as before. i also pulled the back off the pump and checked the oil on the cone. it was almost full.
thanks in advance!!
dave
thanks in advance!!
dave
