hell
a month previously. i had a no start condition, replaced the coil and ground cale cleaned all connections.
this weekend in was riding my ski with no problem for about an hour on almost flat water and hitting 55 mph or so on my 96 gtx.
then all of a sudden the engin sputtered and bogged down. it wnet back up to speed and then bogged again and i would not get more than 10 mph / 3500rpms. during the hour it took me to get back to shore then engine would gain full power for 3 seconds and then drop back to 10 mph / 3500rpms at full throttle.
then engine had no prob starting in/out of water (1500 rpms at idle when usually 3000). i checked the plugs/connections. i cut back the plug wires/cleaned the plugs (black-oily). for some reason when i lifted the plug cap off the plug slightly my rpms would go back to normal. tried new plugs and still the same.
