97 gtx not charging wot
  • 97 gtx not charging wot
    installed new battery and charged it. it cranks and idles fine. when revving past idle the tach goes to zero. digital tach works fine from 0-7000. it has a flashing 12v low on maint light. the problem is that if you run wot on a new freshly charged battery, it causes the battery to be drained comepletely dead in @ 10 min. then ski shuts off. while idleing after a fresh charge it has no 12v low light on. seems to be charging at idle but giving no charge at high rpms @ 2500 or above causes battery to go dead. plese any help would be greatly appreciated. i am a helicopter mechanic and outboard mechanic but am green when it comes to a ski..thanks
    Stator maybe, just a guess.
      Most likely you need a new rectifier, very common on Sea-Doo's. Get it from your dealer.
        hmm, never even thought of that.......good point tech....not to expensive, around 40-45 bucks
          where's the rectifier located in the ski
            bolted to the MPEM(COMPUTER) at least it is on my 97 XP
              Open up the front grey box. The rectifier has three yellow and one red wire coming from it. Fortunately it's easy (and relatively inexpensive) to find/replace.
              -Scope
                Steve,
                The XP and the GTX have completely different ignitions on them.
                  gotcha Bill...thats why i said AT LEAST it is on my 97 xp, but thanks for the tip...i never knew that.
                    thank you much everyone i will update on the repair
