I have read the tech article on the Oil pressure sensor and I was wondering if it ties in with a problem I currently have with my 2002 4Tec.
After doing a pre launch check and engine warm up everything is fine.
Then I launch the ski into the water and start her up and there is a long continuous beep (approx 30 secs) and OIL warning flashes up on the console after the beep goes off the engine runs as normal and does not do it for the rest of the day. Next day same thing.
I have checked the oil levels as per the manual and they are fine.
Could this be anything other than the oil sensor problem?
Also was the oil sensor problem a Seadoo tech bulletin as nobody seems to know about it here in the UK.
