I discovered some light scoring on one piston (mag side, oddly enough) when replacing my base gasket, and decided just to go with a whole new top end including wrist pins and bearings. Is it okay to run some extra XPS oil (1 qt +/-) in the first tank instead of the break in oil, then just go with the normal break in schedule? (should I go longer on the break in than normal, since its synthetic?)
Anyways, fired it up today for the first time, and I did add some XPS to the full tank, but it seemed a lot smokier than usual. (even after the initial runoff of the oil which I coated everything with for re-assembly)
I'm going to bring gas tomorrow so I can dilute it down and get regular gas in there after 3/4 of a tank or so. That should be okay(?)
Cylinders were lightly honed with 400 stones, but the original cross-hatch was still showing in some areas before I did that. What is the best way to break in the new parts? Crank has 28 hrs. Pistons/rings have 0. I got them from SBT earlier this week. Rings gapped, everything checked, cleaned, torqued, sealed, loctited, all new gaskets,copper spray and high tack, etc.
Crossing my fingers this time to be screamin again. Bumped the timing by one degree while I had the front cover off, too. You guys will probably yell at me for this one, but since the timing pickup is a fixed unit bolted to the Mag cover, if you drill out the holes which mount it to the cover, you can elongate them and allow for 1-2 degrees of base timing adjustment (for free) we'll see how that works out after break-in to test the "my boat won't rev past 6700 rpm, it must be the timing" theory. (since everything else has been triple checked and tweaked, and it should theoretically rev to 6900+) - we'll see.
[ May 03, 2002, 10:28 PM: Message edited by: ScreaminXP ]
[img]graemlins/uts.gif[/img]
