how do i remove the inpellor from the pump know i have it on the bench thanks ,marc
inpellor
Remove the screws holding on the rear cap, then remove the cap.
Hold the shaft in a soft jaw vise and use an impeller socket and unscrew the impeller. Keep the pump in the same position and screw the new impeller on.
If you wiggle the pump or lift it off the shaft make sure the thrust washer did not move or you will damage it if ou tighten the impeller. After the impeller is on then you have to replace the cap using loctite on the cap/o-ring area and the bolts.
Unscrew the oil fill screw from the cap and add SeaDoo synthetic oil to the pump.
You want to get it totaly full and it will take 30min-1Hr to let the oil settle in a little at a time untill full.
Now replace the pump using antiseize on the driveshaft/impeller area and pump bolts.Providing mobile JetSki service to the Charlotte / Lake Wylie area.
