can anyone tell me does the small bore water pipe from the exhaust have to go to the pump outlet or can i let it exit elsewhere ,or is it there for a reason . thanks marc
water pipe 93xp
if it is the water pipe I think you are reffering to, it is there to allow water to exit. You should connect it how it was stock.SBT Tech Support is here to help with your problems.
