hx impeller
  • hx impeller
    will a hx impeller part #271000497 work on my 95 spx
    Yes but it will have too much pitch for the 657 motor.
      thanks bill, im new to this,how will to much pitch effect the ski?
        kill your speed or take off.
        <a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
          Rod,
          Did you strip the impellor or the drive shaft or both
            just the impeller,ithink my shafts ok.
              Have you pulled pump and checked it out
                I'll bet you are missing the rubber bumper on the front of the driveshaft.
                  yep bill i was and ican tell on the impeller that ihad didnt have it on because the thing is not stripped deep just on the outer part,chad i did pull it to find this out.shaft not xtremely stripped but has some wear,think ill start over with one of them to! this thing gonna be **** near new when i get done. lol!
                    Yep there is a rubber bumber for both ends of shaft. Well maybe you will get a lot of fun out of it
