Hi!
I bought a XP 800 1997 2 weeks a go and I had plenty of problem with it. If someone can help me I will appreciate a lots. This is my problem:
1. From 0 -25 mph the sea-doo turn bad and seem to make some mise fire sound. It sound like frrr frrr in the exausth system.
2.when I floor it from 0 MPH the engine seem to stuck à maybe 5000 RPM and it take 10 secondes to reach it max RPM.
3. The engine seem to be rebuild (the head bolts has been touch)
4. I have found some water in the coil and in electric wire
5. I checked the RAVE and I cleaned all the carburator (after that ...no change)
I am a mechanical. I also want to said that I am sorry if my english is not perfect. I am from Montreal and I found that site.
Thank you a lot!!!
Guillaume
Thank you a lot!!!
Guillaume
