First off, you guys to a great job here. Technical Support and Bill are awesome. I have been on lots of boards and here are two guys who give give give.
Anyhow, onto my issue. I have tried everything, but here is a rundown. To get my SeaDoo running when cold I can try forever, doesn't even want to TRY to start. I take the plugs out and put in ~5 drops of gas and it fires right up, every time, and it's good until I let it cool down again.
I have tried removing the gas cap before starting. The fuel filter is clean, if I empty it and crank it the filter will fill right back up. Spark looks good. After cranking so much the battery dies the plugs are a little wet, but not dripping or anything and there is no mist when turning it over without plugs.
I hope this sounds typical and has a typical solution. I am a car guy by nature and can turn a wrench but this is all new to me.
Thanks guys. [img]smile.gif[/img]
Wes
Wes
