Ok i read the tech articles again. I know you are probably tired of my questions . But i feel like i am so close to an excellent running ski. It idles fine. They are three different spring in the carb kit which is the strongest. And for any reason should the pressure be different in the carbs. The back is good . Maybe the mag carb pop is too low. Would this cause the load up of fuel before i take these carbs off again. Sorry for all the questions. But i am so so close
Tech another one
Different skis use different pop-off pressures, so the kit has all the springs used in them to cover them.
If your ski is stock don't change your pressure, either set it using a new spring and a pop-off pressure gauge, or do not change your spring.SBT Tech Support is here to help with your problems.
