I purchased four of your rave rebuild kits and I have a few questions. 951 white engine.
1. the ruberband part that is in the kit is this a gasket for a diferent style rave cover then mine or is it to be used to hold the large side of the boot on? Or should I just use the stock springs?
2. Why are there no gaskets with the kit. I should replace them correct?
3. After cleaning one of the valves it has a crack in it. since the engine is stock can I just get a new one from SD or you?
